2008+ Grizzly 700 pod mod
51992 Views 18 Replies 13 Participants Last post by  Binbrook310
Instructions
This is a do at your own risk mod, i don't want to be held responsible for any problems occurred while doing this mod, although you shouldnt run into any. This is a pretty easy mod to do. First, start by pulling off the front cover to access the battery compartment. Start by removing the rack and rack supports. Its needed to remove those pieces to remove the front cover. 2 plastic pop rivets and a snap in the front hold the panel down. Once all that is removed, its easy to get access to everything. With the battery bar removed, remove the 2 philip head screws holding down the EPS control unit. Room is tight, and not much slack on wires, but you need to move this out of the way. Be careful not to pull on wires too much, don't need to be pulling anything loose. After the EPS unit is removed, you will see the ECU. Disconnect the ECU. On the wiring harness you will see a yellow\white striped wire. This is the one that needs to be grounded. I pulled the wire out of the connector, using a paper clip pushing the pin out, snipped the pin off, then soldered on some 18 gauge wire, enough to reach the neg of the battery. Now start putting everything back together. I took a ring connector and crimped it onto the wire, and put it under the screw holding the ground cable down, and it works great. To access the POD settings, heres the directions:
1. Key in the off position, Hold "Select" & "Reset" at the same time. While holding them down turn the key on. The "d IAG" screen will pop up in 5-10 seconds.
2. Press the Select button to get it to the "Co" screen.
3. Hold "Select" & "Reset" again until the "C1" screen pops up. You should see a big "0" in the top of the screen too.
4. Hold "Select" & "Reset" again until the C1 setting pops up at the lower right hand side of the screen.
5. Press "Select" to raise the number and press "Reset" to lower the number.
6. Turn the key off to reset to the new settings.
7. Restart Quad
While in the C1 screen, you can start the quad and the 0 will go up, 3 digits, this is the built in tach, add a zero and thats the RPM. It only reads rpm up to 2,000. This is mainly to set the idle RPM, which should be around 1600, just under clutch engagement.
Test
Some say this mod only effects the first 1/3 of throttle. I noticed a big difference in bottom end, idle, and throttle response. Im currently set at 35, but it takes some testing to figure out what works best for you in your environment. I think its worth it, its free and i noticed a difference.
See less See more
1 - 19 of 19 Posts
:-\I have a power commander on my 09 if I do the pod mod will it harm anything, the commander does not seem to help the bottom end.
With the Power Commander, you should not have to do any pod mod. The pod mod is there for people who want to add more fuel on the lower 25% of the fuel curve without the use of a fuel controller.
Just did this on my 09 Grizzly 700 following your instructions, I must say they were spot on and the mod definately let the machine produce more power. I've got mine set at 50 for now, we'll see how it runs this weekend. Thanks!
nickb2787, not sure how your post ended up with a date 3 months old (check your computer's date) but...I would think the 550 would have the same capability but I'm uncertain as to whether the wiring would be the same. Better keep looking around to see if anyone has done it on a 550. If you're chummy with the tech at your dealership, you might be able to get him to help you out...off the record.
I grounded the yellow/white wire to negative battery post for the pod mod and no results its a 2008 grizz se any answers there is only one yellow/white wire? please help:)
what exactly does this mod do?
EDIT: NVM ;)
I have a 2009 grizzly 700 se, it suddenly developed a stalling, low speed bogging problem last weekend. The plug looks ok,light brown around the insulator and darker brown on the electrode.
(I have to order some more the dealer was out????????)
I buffed off the plug and stuck it back in and the same problem.
So far I have changed air filter/oil/oil filter. no change in operation.
So I thought I would give the pod mod a shot, have not done it earlier because the machine has been flawless in it operation since I have owned it.
questions: my ecu has 2 separate connectors. the back connector is a 25 pin connector and has 3 yellow/white strip wires on it. The second connector is a 18 pin connector and do not see any yellow /white strip.
The wire I believe I want to cut is pin 14 of the 25 pin connector ?
Can anyone back me on this?
Reactions: 1
Gspman, yes on your Ecu there is to connectors. There should be two yellow/white wires. Ground the wire on the right side (one on bottom row) and follow above post to tune. I have done this on my 2013 and worked out great.
i done it on my 2013 550 today its easy and works just got to play with the settings
i got a 2013 550 i done this mod and my fuel setting was at zero.i have played around with it some it seems to run better when i take fuel out but this is new to me may i ask where the stock fuel setting was on your 700??i can go minus 4 or 5 in fuel it runs better but scared of going to lean i cn go plus 3 to 4 and its way to rich any help would be appreciated
i done this mod to my 2013 550 and it works i had it done for about 2 weeks and today i tried to get back into it to try some more settings and it wouldnt display the diag screen any help on this would be appreciated
i done this mod to my 2013 550 and it works or did for bout a week now when i try to get into my diag screen i wont do anything just like if i didnt have the mod done any help would be greatly appreciated
i done the same mod on my 550 and it worked for maybe a week then quit any suggestions of what could have happened...thanks
do you see a yellow wire with white stripe that goes from top of the plug and loops around to the bottom thats the one you want
Old post but has anyone tried this on 16+ models?
Ill second this! I have a 2017
1 - 19 of 19 Posts
