I used my grizzly last winter for grooming and the Actuator on the drag fried the wire harness.. I replaced the Harness , Battery , the Coil , New plug and i still have no spark , There is power to the coil , power to the plug tested with my multi meter.. It turns over but I cant get it to spark.. the ECU says Error 33 which states in the manual malfunction in the primary wire of the ignition coil. but Its a new coil and new harness ? I don't understand when there is power to the plug why It wont spark. Its not a fuel problem the injector turns on and I also sprayed it with starter Fluid. Removing the plug and resting on the engine block produces no spark. the kill switch works as it does not even turn over with it in the off position. I also checked the Fuses. Aggg !!! any help is greatly appreciated..
Welcome aboard!
Man, I'm stumped as well. :sorry:
