my local dealer didnt have a recharge kit for my 11 grizzly 700. would it be ok to clean and re oil my filter with the k&n kit?
The K&N filter cleaner should be ok you can also use parts cleaner ( per yamaha service manual ) to clean your filter . The oil not sure about as its used for oiling there filters which are made up of a different material ( cotton fabric ) . There site says
K&N Air Filter Oil is the only oil specially formulated to work in combination with the cotton fabric in K&N Filtercharger® elements providing a superior air filtration system. When used as directed, it quickly penetrates the filter pleats, where it remains suspended in the cotton fabric. Saturation is maintained until the element is cleaned with K&N Air Filter Cleaner
DO NOT use any cleaner or oil except oil that is designed for foam filter use in which case K&N is not!!!! Oil kits that are offered by companies like UNI will do the correct job for your needs.
Uni Foam Filter Service Kit | ATV | Rocky Mountain ATV/MC
This message is sponsored by the campaign for a 2up Grizzly!!!
