Hello. I’ve had this Grizzly for about a year. It’s 2007 Grizzly 700. I’ve done several things to it, like a BBK and shims, changed brakes and other stuff like that. Most recently I changed Out the cam and oil pump chains.
it started starting after cranking for up to 30 seconds+ before it would fire off. I changed plug, checked valve clearances, etc. the last thing I did Was install a new coil and plug wire. That coil was cheap from eBay. I installed it, checked to see if it was charging the plug, the coil got hot after cranking two times, maybe 10 seconds total. The plug didn’t spark, but the dash lost all power, and hasn’t come back. I checked Fuses, but that’s as far as I’ve gotten so far. Can anyone please advise me on how I should Proceed??
Supporting vendor
Hello,
Welcome to the site!
I would suggest putting back an old coil and check the timing.
I put The ok’d one back on immediately afterwards. I have No power the my dash or anything now. That’s my issue. Timing is dead on though
