okay so here it is im sure this has already been talked about but not sure im ordering a set of 28 skinny to put on all corners an im wanting to know do I need to do any clutch work to be able to keep my wheelies going or do I have enough with just my 1.5mm shim my bike is a grizzly 700 2013gr rules
If you want the best clutch performance call James @ JBS for a custom clutch set up. If you want the least expense and more loss of top end speed add more shim (up to 2.3mm total) and use 18 gram roller weights. Could also change secondary to white spring.
