41 - 45 of 45 Posts
· Too Deep??? Nah!! Watchis
Discussion Starter · #41 ·
I used a lot of the stock vent lines. You'll need probably 3 or 4 T's to tie them all together then just run one up high. This is how I snorkel all the machines I do and it works flawlessly. You'll tie the rear diff into the carb vents (if memory serves me right there is 2 vents coming off the carb) right there by the carb, then run a hose from there up front. The tie the vents from the front diff and fan together. Then hook the one for the rear diff and carb together with the one for the front diff and fan with a T. Then run them into a dummy snorkel like i did or just zip tie them to one of the functional snorkels. You'll probably only wind up needing 3 or 4 feet of 1/8" vent line.
Sint frum tha orijinul smert fone
· Rocko
Thanks a lot man I was debating on snorkelin my 350 jus becuz of the small amount of room in there but now that i c how u successfully did it I'm goin to consider doin the same n I love the gas tank pipe looks real Koo different then other snorkled bikes.
· Registered
My advice to you after snorkeling my machine....dont do the "ball buster"
just come off the side of the air box. I did it this way and my friend didt it the other, less genital friendly way and it is uncomfortable and seems like it is in the way.
ill post pictures soon...
41 - 45 of 45 Posts
