I'm having an issue with the 4x4 not engaging. It worked fine loading it onto the trailer then once we arrived at our destination it would not engage anymore.
I replaced the relays since that was the cheapest start, Can't seem to get the plugs off of the solenoid on the diff but will continue to work on that to make sure everything is good there.
Any other pointers would be greatly appreciated!
Thanks in advance.
Super Moderator
There a good chance it's the switch, not the actuator.
Several guys had issues with it and yamaha did have a tsb on it.
Take the switch apart, clean the contacts , and add some dielectric grease before you reassemble
Sent from my Pixel 5 using Tapatalk
